Old Jul 31, 2009 | 03:49 PM
DTMenace's Avatar
DTMenace
Default Re: Rear hatch rubber stops rubbing off paint?
Originally Posted by LadyMills
My rear hatch is doing that rattling/popping noise (drives me INSANE!) and I've now noticed that the two rubber stops on either side are rubbing the paint off. Anyone else have this? Am I going to have to have my car repainted back there now??? I'm still under warranty...
Apparently you have an early model Crossfire. My 2005 SRT6 (build date 9/04) had the clear tape installed to avoid the rubbing of the paint off those two areas in the hatch area. No issues after 3 years of ownership.
As stated previously, add strips (3-4) to the "U" shaped catch and the rattles should go away. A secondary solution is the use a Torx screw driver and adjust the rubber stops lower.
Good Luck,
Dennis
