Re: NEW Crossfire Emblem Survey
These are different than Andrews emblems. I sent these files to Andrew back in the spring to see if his printer could work with them. Turns out they could not hold registration with the amount of detail. Long story short - these are solvent ink printed on poly, they have a heavy-duty automotive adhesive on the backs.
Here is how its done:
1 - Clean the wing - OEM emblem surface with alcohol.
2 - Remove X-Fire emblem from backing paper. Align/Center your new emblem where you want it. If applying to the stock wings, you do not have to remove the stock emblem. I recommend lining up the top edge flush with the OEM emblem, making sure the “Crossfire” lettering is straight.
3 - Place pressure in the middle of the emblem and work your way outwards in a circular motion. These emblems are pressure sensitive.
It's a little trickier but if you get the top edge on right, and the lettering straight, it drops into place, piece of cake.
