Re: Rear hatch rubber stops rubbing off paint?
A good independent hardware sells anti slip step tread by the foot. You have a choice of textured rubber or sand grit. Both are for exterior use with peel off backing. Buy the rubber version. The adhesive treads thickness will also help with the hatch rattle. The sand texture will start wearing your rubber block stop.Trim to fit with rounded edges. Place on the painted contact area and it will look factory. Squirrel Crusher
