Re: Tensioner pulley
DJ
using your method, is it possible to get the belt back on with the 185 pulley? i know i can slide the belt off, but im concerned that even if i tighten the tesioner pulley so i can crank on it to give the system some play to slide the belt back on, it either wont be enough or the amount of cranking necessary will loosen the tensioner pulley bolt......thats why i was using the other bolt on there
