Re: Pulley Rattle
My water pump went out at 30k with the same rattle and play. Its easy to replace. You can get one off ebay for about $60. There should be no play in the pulley, your bearings are shot. I had to flush my engine and radiator to remove the aluminum particles.
Originally Posted by little wing
No coolant leak yet......probably leave it till it does leak.
Can be sure it's the water pump then i suppose.
