Originally Posted by nate_man
This will be similar to Dans look (Cogicifer), but I really need to know if anyone has these currently on thie car and if they have any problems.
I need to be sure before I make the final decision.
THnx
Unless somebody has these and makes you feel comfortable, you'll need to study the spec's of the tires you've selected.
It's called doing your homework.
When you look at the spec's, take note of the overall section width, and most importantly the
tread width and the overall diameter. These dimensions can vary slightly,
depending upon the rim width. Again, the tire/wheel combo up front should be no larger than
25.5" tall and 9.5" wide. Also take a hard look at the
"sticky" under wheels/brakes/tires/suspension forum called
"Biggest tires on OEM wheels" for a lot of good poop.
Hopefully, you'll hear back from somebody. If not, do your homework and watch those U-turns.
