Old Aug 5, 2009 | 03:25 PM
maxcichon's Avatar
maxcichon
Default Re: Tire Sizes 285-30-20
Originally Posted by nate_man
Max Thanks, and yes this tool is great and have used it befor. Your reply is exactly what I was wondering wether the mm would put me over the edge by going with the 235 up front. BTW what are you running on the rears?
N-
275/30-20's. 35 mm offset (wheel) and had to add 15mm spacer. It will rub the top of the wheel well, on the inside, on a big bump with a full tank and two of us inside. Once again, that 5 mm closer to the inside will make this a little worse, but with the right offset (15 mm?) it would even look better as well as not touch.
As I recall, when I first bought this car, it would rub in this same place with the OEM wheels when I whacked a big bump at speed.
I'm eventually going to 20 mm in back. When I have an extra $100 for H&R's.
