275/30-20's. 35 mm offset (wheel) and had to add 15mm spacer. It will rub the top of the wheel well, on the inside, on a big bump with a full tank and two of us inside. Once again, that 5 mm closer to the inside will make this a little worse, but with the right offset (15 mm?) it would even look better as well as not touch.
As I recall, when I first bought this car, it would rub in this same place with the OEM wheels when I whacked a big bump at speed.
I'm eventually going to 20 mm in back. When I have an extra $100 for H&R's.
Thnx, this is info right on the money. Can or do you have any pics that show where the rubbing occurs on both front and rears?
Also what tires are you running? BTW if i did not have an SSB I would consider your wheels they are really interesting and they do complement you red ride!
