Re: Replace Speaker Grille
Outstanding info guys!
When you use the "full door panel removal method", do you still remove the silver ring and then the grille from the "front" side? It sounds like the silver speaker ring is held in place by tension. That being the case does the "shortcut" method tend to loosen the fitment more than alternative method - or is it 6 of one, half dozen of the other?
