Old Aug 8, 2009 | 01:11 PM
IMPERIAL4EVER's Avatar
IMPERIAL4EVER
Default Re: Burning rubber smell
Originally Posted by MikeR
You can drive it with no worries. The gasket is an RTV like material and they will pull the small cover, clean it all off, re-apply new gasket material and bolt it back on. After a few hours it is as good as new (or better). You should check the one on the passenger side also. It may have a slow/small leak also.
Thank you. What is that part called bolted down to the valve cover and holding the oil cap on? Just so I can reference it to the dealer?
Can someone please answer my question? Also, is this "RTV" material you are referring to readily available at the dealership or will I need to bring the car back?
