Originally Posted by hawksview
for the price it is a good windscreen.Easy install and they fit very well.As far as the seat travel its not a problem.I did notice a little bit of rattle if you dont have the seat back against it but it is very minimal
you can correct the rattle and any friction noise by simply applying rubber kitchen cabinet door stops on all of the pressure points between the bulkhead and plexiglass windscreen. just mark all of the points that touch the windscreen with a marker. then remove the windscreen and apply the rubber bumper on the touching side of the screen, not on the bulkhead. wipe off the marks with alcohol and reinstall the windscreen. if done correctly it really cuts down on the squeaking and chattering between the bulkhead and plexiglass windscreen. you can pick up the rubber bumpers at your local hardware or home depot. i will post pics in my gallery shortly.
