Old Aug 9, 2009 | 01:36 PM
  #76 (permalink)
onehundred80
Default Re: Downloadable NAV CDs
[quote=Mike-in-Orange]UPDATE: As of 8.31.2007 these seem to be working. Please read all notes below.
These disks are for the Infinity Modulus System only, they will not work in other NAV systems. So to share the wealth, so to speak, I have both sets of files sitting on my FTP server and links to both right here:
East Region Nav CD (622MB)
West Region Nav CD (467MB)
Be warned, the files are quite large and are in .ISO format. The following instructions should result in working disks - I tested both methods and produced working disks both ways.
Make sure to use the correct media for this project: CD-R media is the ONLY media that will work. CD-RW discs or DVD media of any type will not work in your Crossfire's NAV unit.
Windows Computers:
Using Nero Burning ROM:
1. Launch Nero and close out the "New Compilation" popup window
2. Select "File" > "Open"
3. From the "Types of Files" selector, choose "Image Files (*.nrg, *.iso, *.cue)" and then browse to the file you downloaded (either XFIRE_USA_0015.1.iso or XFIRE_USA_0015.2.iso) and select it. NOTE: you will not be able to browse to the file until you have chosen the correct file type from the dropdown menu
4. From the "Burn" tab, select "Finalize CD (No further writing possible)" and next to "Write method" select "Disc-at-once"
5. Select "Burn"
6. Once burning is complete the disk should be useable in your NAV system
quote]
For those members who do not have this software and wish to burn these CD;s, Nero has a trial version of this software available to use for two weeks. I down loaded it and used it and it worked OK.
A high speed internet connection is required or it will take too long.
Mike's instructions work, so follow them to the letter.
Go to this site and select the trial version of Nero 9
Nero - Nero - free downloads - latest updates and trial versions
I used the update that is available, it is probably not required but as its free why not use it.
The program installs an icon on the desktop 'Nero Start Smart' do not use it. Go to 'Programs'. select 'Nero', then select 'Nero 9' and from the drop down box select 'Nero Burning ROM' and then follow Mikes instructions, cancelling the 'New Compilation' window etc.
I downloaded these Navigation files from the `SRT6 Documentation' thread to my computer and copied them to the disks from the computer.
