Thread: expansion tank
Old Aug 10, 2009 | 04:42 PM
32krazy!'s Avatar
32krazy!
Default Re: expansion tank
Originally Posted by goodgenes79
well I have to admit I initially used cold steel puddy that didn't adhere well. I got some REAL jb weld kwik set and it seems to have worked alot better. I put it on this weekend and let it set and no leaks as of yet. I guess it pays to use the good stuff. Thanks for everyones help and suggestions. I will probably go with an aftermarket setup when I get a new intercooler, properly seperating the fluids with there own tank.
While I was fixing things I put the DIY belt wrap kit and dual CAI's on and WOW did it make a difference. I think I am set for awhile until I can afford new I/C and tune.
Cheers
are you running stock pullies? when you did the belt wrap did you have any issues with the tensioner being to tight to wrap the belt?
being from huntsville you should check out the car show in the boro every fri. evening. upwards of 200 cars and 2 months ago 700 showed up. good time and place to show off the car!
