Re: C32 Brake upgrade
Hi Lantana,
I was reading through your thread, and understand that you are using parts for a major upgrade in caliper size and rotor size.
What would you use if you just wanted to switch from the single piston front calipers to dual piston front calipers, to still be used with the stock 300mm rotor?
Bat and I took her Roadster and my Boxster to the track last Saturday, and her car suffered severe brake fade at pace, and we want to upgrade the front calipers in order to help diminish that from happening again.
My Boxster has 298mm front rotors, and radially mounted 4 piston calipers at all 4 corners of the car, and it had no brake fade whatsoever, so I'm not concerned about increasing the rotor size on the Crossfire at all.
Thanks for any help you can provide.
BC.
