Old Aug 12, 2009 | 07:57 PM
onehundred80
Default Re: i have about had it with this car
Originally Posted by carpen04
well no it is only in a straight line...on the highway doing about 75 to 80 for 3 to 4 hours straight no stopping and it does it for a breif 5 sec and then it stops and the car does not do it agian..there might be a leak but my dip stick does not show leaks... well i wash i engine bay out and i see water down there..i dont think it could be coolant, cuz it that was the case i would have blown my engine long ago.i will check the bottom of the pan though..
and i dont gun it ...i drive at a constant speed of 75 to 80 for couple of hours and it does it for 5 sec and it is fine for the rest of the trip..
i checked today and no leaks on the ground and looked everywhere except underneath due to lack of lift..so i will inspect it more..
now mind you that it only does this on long trips and it does it on way there or way back never both legs.
How is it that on a long trip like that you spot it every time? My guess is that it happens more frequently and you do not spot it every time.
If the oil is a bit high there is a possibility that engine coolant is leaking past a head gasket and filling the sump with coolant. A little leak like that ruined a GM V6 I had.
