Old Aug 14, 2009 | 07:22 AM
ZAHANMA's Avatar
ZAHANMA
Default Re: if you had to choose
Originally Posted by 32krazy!
you are correct. so i can run the dual cai and the ecu will adapt and then a c3 which needs no tune to run . finally save for a dyno custom tune which will necessitate a trip to eurocharged or let for a tune.
no problem since they are in the same building.
i wonder the same myself and asked that question in the op. it does not use the oem y pipe though. it may be a sl55 setup its definatley not a 32 setup
it is in fact a SL55 y-pipe not a stock SLK32/SRT6 Y-pipe. Restriction gone.
