Old Aug 16, 2009 | 01:23 PM
Eric's Avatar
Eric
Default Re: Is there a difference
is there any pic's of this bracing and is it able to be put on a Coupe. The reason I'm wondering is I'm thinking about making my Crossfire a Targa Top . (DUCKS dodging things being throne at him) (Runs and hides waiting for the mob to move on) Putting bracing on the inside isn't out of the question either such as a roll cage of some sort mby only enuf of one to make up for the loss of the roof but not so big it takes up alot of room make it so some of the bars are removable for everyday use and the put back in for the track hmm just ideas
Originally Posted by RPM
As for as I know, the frames are the same between the two. However, the roadster has additional bracing front and rear that the coupe does not have. The bracing can be removed if needed for working on the suspension and such.
Hope that helps.
