Originally Posted by dyezak
Go to http://www.rceng.com/technical.aspx and you can put in 240hp (our guestimated crank HP), our BSFC (good guess of .45), 6 injectors, 56psi, and .80 max duty cycle and see it comes up with a 19.xxlbs injector. We really don't have the fuel available to go higher safer without larger injectors. If you increase the airflow to the engine and thereby the HP all we are doing is running our injector's past .80 duty cycle, and at that point most injectors spray pattern is getting wonky and the injector will wear out faster causing leaks and the possibility of one sticking open.
So as you can see all the factors hurting the HP and torque are because of engineering trade-offs to lower the emissions. There's a lot of things coming together to rob this engine of power... But the damn thing sure does burn clean!!!!
