Thread: I C Pump
Old Aug 19, 2009 | 10:39 PM
70GT6's Avatar
70GT6
Default Re: I C Pump
Originally Posted by tom2112
Roky & Play:
I would be careful jumping to the pump-is-bad conclusion. Remember a bad pump only causes loss of power when the engine and supercharger are hot. In fact, the ECU shuts down the supercharger when the IC coolant exceeds a certain temperature.
If your car runs fine when the engine is cold, but runs like crap when the engine is hot, then you likely have a pump problem. But if it runs the same all of the time, it's not the pump.
That said: replacing the pump is a relatively cheap thing to do, and it will eliminate one possible problem.
Not entirely acurate - but a somewhat valid point.
It does get worse as the engine gets hot.
But the air temp from the s/c is the critical factor.
Even a relatively cool engine running high boost (and high AIT) will puke with a bad pump.
