(Quote Mr-Roadster) I also tested the rev limiter in my driveway. it's not the sort of limiter I expected. It just jumps up to 4,000rpm and holds there like a crosshair. sounds good, but doesn't have the bounce in it like I expected. (This is in neutral or Park). I guess I had expected it to limit at the redline.
Originally Posted by danimal
Just not the same as hitting the rev limiter when you are wide open in 3rd gear and it's like someone turned the switch off.....different limiter to say the least.
Tha't not your rev limiter. If the front wheels aren't turning, you engine is held, by the computer, at 4,000 rpm. You have to remove a fuse (# 17 I think) to go higher.
Found that out on the first dyno run with my manual tranny.
If your car is stock, Rev limit is about 5750 RPMs.
Roadster with a stick
