Crank Position Sensor
If you get that "my Crossfire just stops running" at an intersection or while on the road and you do get the P0335 OBD II code just go to Ebay and buy the BOSCH crank position sensor. Don't buy the generic one. It is too long and will make a clicking sound when you install it. The flywheel is hitting it and yes the crank position sensor can be filed down with untra fine file just a wee bit to stop the clicking. Be sure to blow it off real good before installing. Well I am off to change my plugs, wish me luck.
