Old Aug 22, 2009 | 05:07 PM
speaks2all's Avatar
speaks2all
Default Re: Crossfire just turns off while driving, and I cant get it started again for a while
Originally Posted by speaks2all
Mine has done this as well
04 Limited with 53K on the odometer.
Check engine light is presently on
Just cleaned the K&Ns and re-oiled (light was on before I did this)
Ran OBD II scan and have two codes
P2099 and P2096
I have a two vol factory manual but can't find codes
any ideas??
thank you
I changed the plugs did a rescan and P2099 and P2096 are gone.
Concerning the engine stopping, if you get the P0335 OBD II code change your crank position sensor (use Bosch only) and that code will clear and your engine will no longer shut off.
