Originally Posted by speaks2all
If you get that "my Crossfire just stops running" at an intersection or while on the road and you do get the P0335 OBD II code just go to Ebay and buy the BOSCH crank position sensor. Don't buy the generic one. It is too long and will make a clicking sound when you install it. The flywheel is hitting it and yes the crank position sensor can be filed down with untra fine file just a wee bit to stop the clicking. Be sure to blow it off real good before installing. Well I am off to change my plugs, wish me luck.
Took about an hour and a half to change all 12 plugs.
16mm deep socket works better then 5/8ths
Short extension and swivel ratchet and a T30 (to take of coils) is about all you need. Watch those shields and work slow to keep from cutting your wrists.
Concerning the crank position sensor, I purchased both the Bosch and generic.
What happened after I put the generic one on is I got a P0300 (OBD misfire code) on cyl 3 (P0303) and cyl 5 (P0305) when I used the manual shift (auto tranny) to shift the car and it started running rough. I put the Bosch crank position sensor back on, re-tested with manual shift on auto tranny and problem of running rough and codes cleared.
