Originally Posted by aussiedude
seriously though, I'd love someone knowledgeable to comment on this.
seems off to me. 321 at the wheels would mean 385 BHP.
That seems a little wild for stock. I made 280 with the needswings intake on a dyno dynamics....since then I added the code 3 pulley, and run mid 12s, so my car isn't abnormally weak or anything...
i was also told the dyno you used is the lowest number dyno. maybe theres a conversion chart for your numbers. i was hoping jake or maybe someone from let would weigh in also. its my first dyno on a car. did a bunch on my harley's but the numbers were as expected. if the 321 hp number was a fluke i could understand but 3 pulls over 310 lead me to believe the numbers are for real. i know nothing of the types of dynos used and this is the only dyno close to me. of course even if i take the very first pull it still showed over 300 hp.
i do know that it seemed if he set the mph numbers higher it ran better. ie: first pull logged from 94 to 110 last pull logged from 115 to 158. dont know if it made a difference but the ecu seemed to like it. revs at 6012 and the ecu shifts the car into overdrive or shyt it down. 5800 seened to be the magic rpm
of course aussiedude it could just be the badging!!
