Originally Posted by velociabstract
I have the last generation aluminum Code 3. It used no shims at all. If I remember correctly the installed clearance on the stock pulley was 45 mm to the clutch. My Code 3 had varying clearance when new. 25 mm at the tightest point and 47 mm at the widest. I was told it would wear itself flat. I measured from the bearing like you but can't remember exactly what I found but it was not even from one side to another. Sorry quality control. But the sucker works flawlessly and I love it. Don't try to make the numbers match. They wont. Put it on, measure the clearance to the clutch for posterity, watch for signs of the belt slipping (mine doesn't) and fry the tires. Since you have shims, I'm pretty sure 20 mm is the recommended clearance between the pulley and clutch in the install instructions from Code 3. You might check the website to be sure.
Les
thats the issue im having. most that have the c3 use none to 1 or 2 shims. with 5 shims in measuring 1.60 mm thickness the pulley is in full contact with the s/c clutch. no clearance. brandon is sending me some new shims but i seem to need more clearance than any other c3 out there. from oem there is .80 difference from the edge of the bearing
i really dont want a crank pulley. i avoided using c3 for a new pulley due to so many negative posts by members. getting it from a reputable shop used seemed like the best of both worlds. not so sure now. and to top it off my oem shows definate signs of wear from the bearing so putting it back isnt gonna happen.
the c3 instructions also call for .20 to .30 mm clearance i believe most confuse this with 20 to 30 mm major difference
