Old Aug 25, 2009 | 01:31 PM
onehundred80
Default Re: Leaking Coolant into engine oil
Originally Posted by Seoman
My wife and I just purchased a Ponitiac G5 GT as a daily driver that was a demo with 5000 miles, so we are the official first private owners. When we got it home we noticed the antifreeze was low and so just filled it up assuming it was low from the factory. Well, it wasn't. A couple months later
it was low and so we took it to a Ponitac dealership with the expecation that they would fix it.
They couldn't find the leak, so they pressure tested the coolant system. Still nothing, so they dyed the coolant and told us to go drive it. Did that, took it back, and they said it was the head gasket and they said they replaced it. We have the paperwork that says they did that when we picked it up thinking they had fixed the problem.
Last Friday the coolant was low. So back to the dealership it goes. Now they are saying they didn't replace anything on the car last time (even though we have the paperwork saying otherwise) and that they still don't know where it is leaking. Unfortunately, we think that the antifreeze is getting into the oil because what appears to be frothy snot formed on the oil cap. Dealership is saying that is just condensate, but that sounds like a load of BS to me.
They now want us to just drive the car because they don't know what is wrong with it. This obviously doesn't sound like a solution to me.
Car is GM certified 4yrs, 48000 miles. Has 13000 miles now. 100000 mile powertrain.
Lemon Law is first year/12000 miles, 3 visits unresolved (we are at 2).
Options? Opinions?
I had an '88 GMC van with a 4.3L V-6 engine and GM had trouble with the head gaskets this resulted in a major recall in the States, in Canada no recall and no help unless it was really obvious.
My van used anti-freeze up quite slowly, there was a leak around the water pump and I felt it was just that problem. I did not know that both head gaskets were leaking. This resulted in major damage to the engine, I complained that I was using a liter of oil in 200 miles, the stealership said they would monitor it in a test carried out over time. I told them I knew it was burning oil so why do the test, they just gave me the runaround. When the car started belching smoke I was past any warranty and investigated it myself. the steel oil cap was rusting out from the inside and was filled with moisture and a white slimey goo.
I decided to take the engine apart bit by bit, I found the engine sludged up, and oil galleries plugged with sludge, under the head covers I found cup fulls of sludge. I ended up taking the engine out and had it rebuilt with top quality parts. All the bearing surfaces were ruined, the push rods were three sided instead of dome shaped just like it had been put on a hand grinder.
That was the last GM vehicle I purchased, my last five have been Chrysler's.
