Originally Posted by vladd
Just a little update. I'm letting the engine cool down right now so i can pull the plugs and check them, and clean any that need it. The problem is very odd, if it idles rough when i crank it up then it won't accelerate well at all, stumbles and has no power (obviously still misfiring) but if i turn the car off long enough to run into quiznos and come back out it'll run fine (and the CEL is still on from before). Power comes back and zero issues, so it's either there or it's not, no middle ground.
Having the same issue with cylinder #3..Started pulling codes right after I let the tank go low.....have put some injector cleaner through it but think I'm going to suffer with this until I get more mileage on it....Hoping this tank will flush things out...Going to pull the plugs and check for any crap on them.....Thanks to Woody for that article...
Have to drive to Nova Scotia soon and want this fixed beforehand...
