Old Aug 25, 2009 | 09:16 PM
Franc Rauscher
Default Re: can I realistically buy a good srt6 for $15k?
Yes. It will have some miles on it and likely issues like the IC pump failing but I've seen several at $15K to $16K.
'Verts seldom go for less than $20K so I assume a Coupe will do.
They are out there but seldom here on the forum as these guys take care of their babies.
Another approach would be a higher milage '04 NA in the $8K range . Then spend $6K to $8K on a twin turbo mod. 330HP or more is doable and you can opt for a stick shift.
roadster with a stick
