Old Aug 26, 2009 | 08:04 AM
racerx's Avatar
racerx
Default Great Rear Camber Adjustment Solution!
After doing alot of research and not being totally comfortable with the install problems and adjustment limitations of the Kmac kit, an MB dealer suspension guru referred me to Jeff Short at www.speedybenz.com. He is located in California and manufactures heavy duty rear camber arms. They are easily installed in under 1 hour per side with normal hand tools, give a much wider range of positive or negative camber, and are simple to adjust.
The arms are priced less than the Kmac kit and i got them in under a week.
