Old Aug 29, 2009 | 07:45 PM
waldig's Avatar
waldig
Talking Re: Hitting the books to get a better angle on it
I redrilled the mounting holes in the frame on the inner end of the lower rear wheel strut.
Moving the arm inboard 0.1" was enough to fix one side, the other side took about 0.15". Remember this arm is about 4" off set from the center of the wheel giving you a bigger change than the 0.1" or so. Its like a 4 to 1 leverage due to its position which allows such a change with a little enlargement in the hole, sorta oval shaped.
Both of my rears are at 0.6 degrees of negative camber. This is not done yet as I have been alerted to check the toe in and toe out angle as causing the dreaded wear pattern on the inner edge of the tires. Iam going to see if I can measure the toe accurately, something more to do...................
WEEKEND WOODY................
