Old Aug 29, 2009 | 08:14 PM
MikeR's Avatar
MikeR
Default Re: What is this line ? help
YES. You need to download the servce manual and parts manual from the SRT6 forum. Here is the fuel rail removal procedure.....
1. Disconnect the negative battery cable.
2. Remove the air cleaner housing.
Refer to Page 9-608.
3. Remove the fuel rail trim panel screw and then remove the fuel rail trim panel (1).
4. Release the fuel pressure through the fuel rail service valve (7) using a fuel pressure tester. Collect the fuel in a
suitable container.
5. Disconnect the fuel feed line (3).
6. Remove the fuel injector wire harness connector retaining clips and then disconnect the fuel injector harness (6)
from the fuel injectors (4).
7. Remove the fuel rail retaining bolts (8).
8. Remove the fuel rail (2) with the fuel injectors (4) by moving the fuel rail (2) side to side while lifting upward.
9. Remove the fuel injector retaining clips and the fuel injectors (4) from the fuel rail (2).
