Originally Posted by Rasim
Thanks, but i quess i can use my oem Y pipe as experiment to do a port in a center of Ypipe, because my SL55 intake with it's y pipe has just come.
about throttle reset i did it but differenly, the method there need to push accererate pedal in floor for 5 sec....." is the Core same with "
disconnect the negative battery terminal for 30 minutes and then reconnect. " ?
wrong y pipe, the one we are reffering to for the boost gauge tap is the aluminum/magnesuim ypipe located under the air intake below the throtle body
i havent tried that way to do the reset but i imagine it would do the same thing on your c32
