Old Jan 19, 2005 | 03:54 PM
Epyon
Guest
Posts: n/a
Default Re: DYNO Numbers(or lack there of)
Originally Posted by Bullseye
Been gone the last few days, the dyno sheet didn't pop up but someone said i was pretty close. I would still like to see especially Mpecic? the man with true duals run a dyno, be pretty interesting. If we can get these cars up to 200 whp i don't see why we cant run 13's with perfect conditions, right now on the same whp we run what Acura RSX type s's do or a bit quicker, all they need is 200 whp to run a high 13, so ratio to ratio we should be the same if not a high high 13 a low 14 for sure.
it won't do that since the car has no limited slip, its a open differential, and the torque band is too wide. a real tuner would f around with the gear ratios and make the car go faster that way.
