Originally Posted by BlueStorm
sounds like a similar set up from Startec, it will easily may 300hp, but you guys wil end up paying $4000 maybe more for that power.
If you can get a crossfire with blown motor or minor damaged for $5k there is a crate 383 from GM cost $4000 it's the HT383, then there is the race version ZZ383. Simple TBI will put out 350 hp and over 450 Ft lbs on te HT motor., under lowboost it makes 500hp
even better, if you already own a crossfire buy anothone same color, this way you can modify one with a crate motor and use the other for smog inspections. just swap lic. plates now you will have fun destroying every AMG on your block
i think somebody forgot about all the issues with the electronics when you swap in any other engine other than the n/a m112
