Thread: c3 question
Old Sep 2, 2009 | 10:25 PM
32krazy!'s Avatar
32krazy!
Default Re: c3 question
Originally Posted by tighed1
Yep stock belt with the Code 3 and the 181.
Should fit on your application since you "still" have the stock crank pulley. Make sure the belt is properly seated all the way around all other pulleys. Doesn't hurt to double/triple check.
still cooling down. ill check tommorrow when i get home from work
