Old Sep 4, 2009 | 08:48 AM
Rasim's Avatar
Rasim
Default Re: 178mm needswings pulley is installed. need a help
Originally Posted by cruzinquick
I think you were misunderstood due to the language barrier. The flashing tool method is probably your only option if you don't want to send your ecu. Now since you have a C32 you have several options. Check the MB board for the best tune suited for your mods. In addition to InMotion, and Let there also is dyno-comp which uses renntech tunes, powerchip, kleeman, and evosport.
I'm biased with my InMotion tune. I have the smallest crank pulley 178, but currently the 2nd fastest SRT6 around. Now to be fair my tune was specifically created for my Needswings parts combo. For being a version one of this tune, it sure is a good one. I suggest that you get some feedback on the C32 section of MBworld. There may be an affiliated tuner in Germany that would make it more convenient. I'd even try Korea or Japan for additional options. It's going to be expensive any way you look at it.
That is what i want i just do not want my car to stand, i can not stay with out my car, can you talk with them to provide me any solution to tune up my car ?
