Old Sep 6, 2009 | 07:52 AM
NeedsWings's Avatar
NeedsWings
Default Re: 178mm needswings pulley is installed. need a help
Originally Posted by Rasim
so you think i need to remove the chip from my ecu and sent to inmotion?
you will most likely need to either put down a deposit on the interface to flash the files in yourself or send the pcm in for the tune. your stock chip is not removable from the ecu so you would need to send the entire ecu.
