Old Sep 8, 2009 | 12:48 PM
bigdan's Avatar
bigdan
Default Re: Engine Tick Video...any ideas?
Sounds like a rocker arm or tappet on one of the valves. If it can be repaired without removing the cylinder head, it shouldn't be too bad.
A shop would take the valve cover off, protect the engine bay from oil splashing all over, and start the engine to identify exactly which valve it is.
If it's a broken valve spring, bent valve, etc, then the head probably has to come off for the fix. That would not be good.
