Originally Posted by 32krazy!
is the motor readily available? is it a diy replacement? i know the seat heaters were an issue i was waitnig until winter to take the seat apart to fix. if the motor isnt a gazillion dollars ill replace it if its the culprit
I couldn't tell you any of that info..............the last time I saw one replace was when I was working for M-B of Houston back in 2002(and they were replaced under warranty). First you need to find out if that is in fact what's wrong with it. Best bet is to jump the seat motor with 12volt power(and ground) and see if it moves..........if it does then your switch is probably bad.
