Old Sep 9, 2009 | 05:54 PM
  #39 (permalink)
32krazy!'s Avatar
32krazy!
Default Re: Do it yourself DIY Belt Wrap Kit for less than $25
Originally Posted by ProjectMayhem
Well you could always get the ribs shaved off of the pulley and make it flat that would give you the few MM you need for clearance. Just call a few local machine shops and see if anyone will machine it down for you.
ill take it to a machine shop tommorrow and see what can be done
goodgenes has the same setup and isnt having issues so i may try it for a day or 2. i had it setup and running but felt it was to close for comfort
jason i have a bracket to support the pulley. its not as cool as robs but should work ok!
