Old Sep 10, 2009 | 10:26 PM
onehundred80
Default Re: Multifunction Tool Located
Originally Posted by rdougc
one important use would be to remove the front lower gril cover in case you would need to have your baby towed.If you have a roadster you need it to raise the top in case of malfunction. Come on people what are some more uses.
rdougc
Breaking the door glass so you can get in and sleep it off after someone took the key because you had too much to drink.
Releasing the auto transmission from park to neutral without a key so it can be towed by the local police department, because you had too much to drink.
Chiseling a hole in the cell wall so you can escape from the local lockup.
I could go on and on, its priceless, don't leave home without it.
