There's only two things that can go wrong on the install...........
1) You didn't snap(both tabs) in place onto the throttle body
2) You didn't plug in the one(about 1/2'' OD) vacuum hose on the drivers side inbetween the airbox and throttle body
Even if you messed those two things up I still don't think it would effect the car's idle though.
i do not forget about vacuum hose, i could snap only 1 tab that is upper i can not be sure about the second i just do not see and human hand is big to check it by touching it physically. i thought it should be like and i just to adapt throttle, no?
