Old Sep 13, 2009 | 05:08 PM
James1549
Default Re: Help?! Convertible Button Fell... how to get???
I don't have a roadster but this may help.
The next silver section forward should just pull up and off. Gently pry with a plastic tool of some sort to prevent scratcihing. This will expose 1 or 2 screws to remove. With some effort, pull the rubber handle off your parking brake lever. Then open your your console compartment, peel back the carpet liner and you will find two 10mm bolts to remove. The console should be removable then. Becareful of the mirror wiring and air line to the lock.
Anyone else is welcome chime in. James
