Dual Cai ideas from Woody
Sep 14, 2009 | 07:55 PM
permalink
waldig
Feb 2008
4,508
34
VA
I wanted to share a few ideas that I have incorporated into my Crossfire. THese are to assist in the longevity of the car overall and decrease stress overall.
I have added some simple braces that bolt on to the intake manifold and are held in place with a hose clamp. See the photos to get a feel of how I did it. I used LOWE's aluminum strap and bent it in a bench vise before buffing the braces. Its easy piezie to do.
This is to limit the motion forces that the throttle body sees as the engine flexes during wide open throttle operation. Remember that my motor is strapped down to limit the rocking the block see under full power shifts. The long inlet tubes act as a lever arm and I wanted to arrest some of the force involved.
To further minimize the shifting forces, I DID NOT CLAMP the inlet tubes to the rubber hose going thru radiator support. There is sufficient sealing for me and the lack of a clamp allows the tubes to shift in the rubber hose tube. I also added some silicone grease to the inside to prevent sticking of the hose/tube interface.
By masking off the nedswings logo, I sanded the nameplate with 400 and 1500 grit. After getting the letters smooth I used mothers aluminum polish (Walmart) to get a polished finish. I thought the little touch added to the overall look. I am currently working to polish the tubes over their entire length, and will show it when done - puff puff.
I go to the firewall ALL the time and this seemed to be a good idea, and may stem long term stress(es). How you enjoy the thoughts, Woody
Applicable to single inlet CAI's also...........WW
07:58 PM
waldig
View Public Profile
Send a private message to waldig
Find all posts by waldig
