Re: Rotrex Guy
You already have the AEM wired in? Mind me asking where you ended up putting it? I hope the added wires were long enough and the fact that some of the lettering on them not being there anymore wasn't a problem with following the wire down and then it changing colors and then going back. I needed to snake it through the hole in the ECU box under the hood through the firewall so it needed an extension.
Glad to see you're making progress. FYI, spend a lot of time on MAF simulation and get that bugger ironed out before you start getting to far into it. It will make things a lot easier later on if you're using just the MAP on the AEM to change your fuel maps.
Good luck and let me know if you have any questions.
