If they sell WOT boxes for our manual cars, then that should take care of the problem.
What is the WOT Box?
The WOT Box is an electronic device that makes WOT shifting easy by reducing your engine's power for a very short timed period while you shift. It allows the synchros in your transmission to mesh easily, reducing the chance of missing a gear and damaging your transmission. If the input shaft on a manual transmission is not allowed to slow down enough it will lock you out of gear time after time. We have developed a solution to the problem by controlling the ignition at the shift point to ease the transition from one gear to another.
The WOT Box momentarily disrupts the engine power long enough for you to make an effortless, fast WOT shift. The result?
- Lower ETs
- Reduced chance of missing a gear
- More consistent, effortless shifts
- Reduced wear on the transmission
- Reduced chance of major transmission damage
