Old Sep 19, 2009 | 06:36 AM
  #431 (permalink)
LantanaTX's Avatar
LantanaTX
Default Re: V8 Crossfire Conversion Diary
Originally Posted by bigblock427
Perhaps this ODB -> ODB II adapter will be a solution?
Küster DatenSysteme OnlineShop
It's worth a try.
There are also other adapters availble (if you need other plugs).
Perhaps these adapters will also be available in the U.S.
thank you for the link. That is interesting. Some SLK320's came with the 38 pin connection in the fuse box as well as the OBDII under the dash. I wonder if that the part of the wiring harness that that includes the fuse box and 38 pin connector can be adapted to the crossfire. I wonder when Mercedes started using this since some R170's had it and some only had OBDII like the Crossfire.
Kanzus (Karim) any ideas?
