Old Sep 19, 2009 | 10:18 AM
onehundred80
Default Re: Brake Lights ??? Constant On!
Originally Posted by arherrington85
So I replaced the yellow switch in the LF fuse box and I still have the same issue.
1. With the exterior lights OFF, I apply the breaks and after about 1.0 seconds the "!" for the lights appears on the dash. A clicking can still be heard coming from the newly replaced switch.
2. With the exterior lights ON, the brake lights are on constant as if I were driving while holding in the break break.
Any ideas? Thank you.
The brake switch is actuated by the brake pedal and is mounted beside the pedal under the dash. You replaced the brake switch solenoid. Maybe the switch just needs adjustment or it is loose.Have a look it is easily seen. See page 8L-91 of the shop manual.
Start at the switch and hope it is nothing more serious like the module.
