Old Sep 20, 2009 | 05:46 PM
ammoman's Avatar
ammoman
Default Re: Head work done, 216 to 318 CFM!!
Humm? Your not the first to port heads. If you only had 216 cfm to start you must have had a bad set of heads. Is it possible that some one just made a mistake with a few numbers. Any way 318 cfm is impressive if you realy started with only 216 and went to 318. However if you started with 270 ish cfm and went to 318 cfm for $1500.00 it's not impressive at all about $32/cfm.
