Thread: DOT 4 Plus...
Old Sep 22, 2009 | 09:26 AM
AllEuro's Avatar
AllEuro
Default Re: DOT 4 Plus...
You should just use Motul RBF600. Check it out here: Discount Motul 600 Brake Fluid - RaceShopper.com
I use this stuff to track my corrado and I also buy it from these guys. I've never had a problem. I used to use ATE Superblue, but I heard bad things about the blue dye and the various seals inside the brake system. So now it's exclusively Motul. I'll probably use this stuff when I change out the fluid in the crossfire. Though I think it's a bit overkill on a car only driven on the street--or even autocross.
